Ford Lariat- Popping noise when turning
Old Mar 31, 2007 | 10:02 PM
Higgy1982's Avatar
Default Ford Lariat- Popping noise when turning
Hi all. I have a 2000 Ford Lariat 4X4 F150 (75K miles) and once in a while whenever I turn the rear makes a popping noise. Almost sounds like something is rolling around in the bed of the truck. Just last week I replaced the U joints (both front and back). Any suggestions?
Old Apr 1, 2007 | 09:02 PM
goinstrong's Avatar
Default RE: Ford Lariat- Popping noise when turning
Could be a busted tooth on an axle gear or broken brake parts on the rear wheel. If you ever had an axle seal go bad - they could have dropped a part in the axle case and left it (common).
Old Apr 26, 2007 | 01:34 AM
speedfever22's Avatar
I would check the crossmember and make sure the ball joints in the front are still solid
billpolkjr
May 30, 2013 09:47 AM
billpolkjr
May 29, 2013 01:33 PM
03expyeb
Feb 2, 2008 04:23 PM
texasquail
Jan 29, 2007 12:17 AM
mad man
Jan 4, 2006 03:17 PM
