Front End
Old Jan 11, 2008 | 08:17 PM
4thgenaccord's Avatar
Default Front End
Ok, well this started a few months ago, the tires would wear out on the inside, i took to shop and they said the ball joints had play in them, and said that its ok to drive, it will just keep wearing out the tires...so later on the front end started making a whirring sound while going down the road and a sqeaking sound, then tonight when i went down road the the truck would like bounce up and down and make a popping/weird grinding sound when im just going down road....and the truck would pull real bad, not always, but sometimes it would do it, like for instance, like if your behind a semi, and the wind is hitting you on interstate... Im worried to drive it, i dont want the front end to like just fall off while i ride down the road...So it would be greatly appreciated if someone could like diagnose this for me without looking at....or just tell me some things that could be possibly wrong... its a 1998 Ford f-150 with 211k on it...thanks
John
Old Jan 11, 2008 | 09:25 PM
btexpress's Avatar
Default RE: Front End
You're kidding, right? You have already had a shop point out a problem to you, did you fix it or not? This is not something to diagnose over the internet. We can tell you common problems, but only physically inspecting/checking the front end will get you a decent diagnosis
Old Jan 12, 2008 | 09:12 AM
oldtimer35's Avatar
I see possible wheel bearings, ball joints and tie rod ends. All of which need to be looked at by a professional and soon. These can lead to more problems, if they haven't already.
hardbalance
Apr 12, 2015 08:48 PM
2verb
Jan 7, 2014 11:32 PM
Socal4521
Aug 2, 2005 03:41 PM
jaguar390
Jul 14, 2005 02:42 PM
Lonny
Apr 8, 2005 02:13 PM
