Fuel tank
Old Dec 31, 2018 | 12:34 AM
Mmeyer51's Avatar
Default Fuel tank
I just replaced my rear fuel tank on my 94 f150. Sending unit not working now. Haven’t used tank in about a year I’d say. Sending unit worked perfectly fine before though. Could the sending unit have gone bad, or maybe it just needs time to be able to start reading correctly again?
Old Dec 31, 2018 | 10:32 AM
Welcome to the site..
Not working, reading what level if any?
Could be an issue after the swap with the sender itself, or, the brass type floats likedl to crack under the ‘C’ portion of the senders arm. If cracked, the float fills with full and sinks to the bottom of the tank always indicating empty..
There’s no relearn...
Old Jan 2, 2019 | 01:45 PM
Mmeyer51's Avatar
Reading on cluster is past full. All the way past full to where arm won’t go over anymore on it
Old Jan 2, 2019 | 08:55 PM
If the sender wire shorts to ground, you’ll get an extreme high reading.,
Old Jan 2, 2019 | 10:28 PM
Mmeyer51's Avatar
Okay, I’ll have to check it out then. Thank you!
joshua
Oct 31, 2018 09:59 PM
Deaston
Jan 25, 2018 07:21 AM
69BirdWatcher
Dec 4, 2010 11:26 PM
wreutelh
Nov 17, 2008 01:51 AM
lthacker
Mar 5, 2007 10:59 PM
