Gas Tanks
Old Sep 10, 2008 | 06:43 PM
CUSTOM 1981 4x4's Avatar
Default Gas Tanks
Well I logged on this site hoping to see if I could get some help....
Here's my problem, I have a 1981 F-150 with dual fuel tanks. Well after about the 200,000 mile mark my fuel guage went bad and I checked the grounds, the fuses ect. My worst fear was the sending unit was bad and it is. I dropped my16 gallonside mount tank and noticed it was covered in rust and sediment (I'm sure my back tank is worse).
So I took it apart, drained the fuel and rust. Cleaned it with water and used an air compressor to get the remaining water/fuel mixture out. Now I'm buying a new sending unit and all that, but the big issue is when I went to start up my truck it wouldn't turn over (as I ran it on my back gas tank). It was just a very simple "Click" noise. It wouldn't try to turn over or anything just one click and if I tried to start it again I'd hear nothing.
I wonder if the truck can't function if I removed one tank, or somthing else is going on here.
Thanks Pat.
Old Sep 15, 2008 | 10:49 AM
Bullitt94's Avatar
Default RE: Gas Tanks
It should be able to run with only one tank.
Old Dec 8, 2008 | 11:14 PM
88 F150 351w's Avatar
check your positve cable to your battery.
roadsportusa
May 8, 2024 04:41 PM
Scav
Jan 28, 2020 01:06 PM
oldad
Aug 2, 2012 08:11 PM
Fordster
Jul 7, 2010 03:56 AM
JimP
Mar 8, 2005 03:30 AM
