Got the f150 running
Old Jul 23, 2020 | 09:46 PM
F150-07-4.6's Avatar
Default Got the f150 running
I changed the number 27 fuse and now it starts but the AC doesn't work now... Getting code PO354?????
Old Jul 24, 2020 | 07:18 AM
raski's Avatar
The code and the a/c are not related. P0354 means there is an electrical issue associated with coil -D, which I assume is for cylinder 4.. Try swapping that coil with another cylinder and see if the code changes. Bad spark plug for # 4, wiring issue with the primary side of the # 4 coil, manifold vacuum leak affecting that cylinder are some things to check. I don't know what fuse 27 is for but it could have blown again, cutting power to the a/c field coil. If the a/c worked before fuse replacement, check other fuses as I would believe an electrical issue exists for the a/c. I hope you disconnected the battery before you worked on it or you could have created new issues.
Hunter13
Jan 23, 2017 05:22 PM
xkittycurbstomp
Nov 18, 2015 01:35 PM
JamieA
Jul 19, 2012 06:54 AM
drjoe
Sep 19, 2010 04:06 AM
judy_bug08
Aug 19, 2007 07:06 PM
