Hard to turn to the right
Old Nov 29, 2007 | 09:49 PM
slow450's Avatar
Default Hard to turn to the right
I have an '90 Ford F-150 where turning to the left is no problem. However, turning to the right is another story (like no power steering). I just installed a new power steering pump. Did not fix the problem. If I jack the front tires off the ground, it turns fine with the engine running and with the engine off I can manually move the wheels (turn). With engine running and one wheel on the ground it turns fine but with both wheels on the ground it is back to left OK and right bad. Your help is appreciated.
Slow450
Old Dec 5, 2007 | 11:28 PM
jr78's Avatar
Default RE: Hard to turn to the right
Sounds like you need to replace the steering gearbox. If the ps pump was bad it would be hard to turn both directions not just one.
JR
Transit04
Sep 21, 2012 02:07 AM
squarebush
May 4, 2009 11:19 PM
Dongo
Dec 28, 2008 11:58 PM
beat_dog
Apr 22, 2008 10:45 AM
auctioneer
Oct 19, 2005 10:25 PM
