head lights. PLEASE HELP!!!
Old Mar 14, 2009 | 01:35 PM
coford's Avatar
Default head lights. PLEASE HELP!!!
i've been trying to fix my head light for almost two weeks now and i still can't find out what the problem is. i've checked all the fuses, i've checked all the relay fuses. i even replaced the head light switch and still no luck. please if anyone has any advice, throw some my way before i rip my truck down and start selling her for parts. thank you
Old Mar 14, 2009 | 06:53 PM
Bullitt94's Avatar
I'm assuming your lights aren't working at all?
I'd try cleaning the grounds for the lights.
Old Mar 14, 2009 | 11:39 PM
No high or low beam?
If the 30 amp fuse/position #8 in the Power Distribution Box is blown you wont' have any headlamps.. If the 30 amp is good, and the H/L switch is new with 12v in on the DB/O wire and out on the R/Y wires then the circuit is good through the H/L switch.. You can also check for voltage on the same wire color/tracer at the multi function switch connector, only the voltage 'out' of the mutifunction would be on the GY/O and R/BK wires to feed the junction box fuses.. You should also have 'voltage' at the junction box fuses for high lamps/flash to pass, low lamps when commanded with the mulit function switch.. Check to make sure the voltage is there, and not just an open fuse.. Fuses are #16/20 amp for high, #28/10 amp for lows, 26 for DRL's.. If you have voltage at and through the junction box panel when selected with the multi function switch, then it could be in the connector up close to the firewall drivers side, the harness out to the lamps, or a ground issue as Bullitt94 stated.. Did the lamps work prior to the dash work you recently completed?
willy j
Oct 9, 2025 03:02 PM
bgraef
Nov 10, 2010 10:12 PM
STG
Oct 20, 2009 01:07 PM
vardslane
Oct 8, 2009 09:10 AM
Laramie1997
Mar 31, 2009 08:19 PM
