inner tie rod ends
Old Feb 1, 2007 | 11:18 PM
realgem63's Avatar
Default inner tie rod ends
I'm having problems with my inner tie rod ends.I've replaced them 3 times in the past 2 years.I just had them replaced this time after only 8 months.I own a 98 F150 4WD with the 4.2.I use my truck for work,but it doesn't get used very hard.I rarely use 4 WD.I also replaced the idler arm last year.Anyone have any ideas?Thanks!
Old Feb 2, 2007 | 12:38 AM
wheelsup68's Avatar
Default RE: inner tie rod ends
What manufacturer are you using for the replacement parts? Same every time? May think about a new vendor.
Old Feb 3, 2007 | 11:10 AM
realgem63's Avatar
I don't do the work myself.My cousin who owns a garage does.We are on the 2nd manufacturer.The first was Moog.This time he used a brand from Autozone with a lifetime warranty.I guess we'll see how it goes.
Old Feb 4, 2007 | 03:30 AM
1954ford's Avatar
i'd try using ford parts, they usually aren't much more expensive than aftermarket stuff and the quality is way better, also are you having it aligned on a machine or by sight, do you have over sized tires, are the parts being greased when they are put if they have grease zerks, all of these thing could contribute to premature wear, good luck
qr3379
Apr 11, 2012 07:32 AM
billj818
Nov 13, 2006 12:35 AM
billj818
Nov 5, 2006 11:39 PM
gopher
Apr 23, 2006 01:17 PM
Bigg_billy
Sep 11, 2005 12:24 AM
