replacing inner tie rods on Ford Ranger
Old Nov 5, 2006 | 09:30 PM
billj818's Avatar
Default replacing inner tie rods on Ford Ranger
1999 Ford Ranger, 3.0 liter V6, 2 wheel drive, coil spring front suspension.
I plan on replacing the inner tie rods on my Ranger. My question is: Do I have to remove the steering rack, as my Ford factory manual states to change the inner tie rods? It looks to me as if I remove the outer tie rod ends and the boots (bellows) I would have enough room to unscrew the inner tie rods while the rack is still on the truck. Thanks, billj
Old Nov 5, 2006 | 10:43 PM
wheelsup68's Avatar
Default RE: replacing inner tie rods on Ford Ranger
There is no need to remove the rack and pinion. easy replacement just as you stated in your post, then have aligned afterward.
Old Nov 5, 2006 | 11:39 PM
billj818's Avatar
Thanks for the reply. Looks like an easy enough job.
qr3379
Apr 11, 2012 07:32 AM
Priscillatx
Apr 26, 2010 10:42 PM
realgem63
Feb 4, 2007 03:30 AM
billj818
Nov 13, 2006 12:35 AM
gopher
Apr 23, 2006 01:17 PM
