lift questions
Old Mar 20, 2006 | 02:00 PM
mexiburger's Avatar
Default lift questions
ok I am a little confused about using a body and a suspension lift a the same time. I have read alot on this and in diferent places i have read that you really should not and other places it said that it was ok. i just want to know this because when i get money i want to know what i should buy.
thanks
mexiburger
Old Mar 20, 2006 | 03:34 PM
1984/351W's Avatar
Default RE: lift questions
Its perfectly fine to run a BL and a Suspension lift. I run a 4' suspension lift and a 1.25' BL on my Wrangler with 35's. Are you going to do any off-roading or is it going to be a pavement pounder. Im not a fan of body lifts over 1' they look stupid and if your body mount bolts break from all the stress its not going to be pretty.
Old Mar 21, 2006 | 01:18 AM
mexiburger's Avatar
thanks for the reply, thats what i wanted to hear.
I am defenatly going to go off-roading, i hate when people have nice trucks and all they do is drive to work. It's just too much fun off-roading.
I have a few more questions now....
would you say that the more body lift you have the more dangerous it is?
How is the shift linkage of a standard trans affected?
thanks
mexiburger
Old Mar 21, 2006 | 01:03 PM
1984/351W's Avatar
Once again the taller the BL the more of your shifter is going to be gone. If you have a 1' BL you lose 1' off of your stick, and so on. For linkage problems, this is why I only have a 1.25' lift, I dont have any linkage problems. I can shift fine and I can put it in 4wd just as easly. What size lift are you going to go with and what brand. Are you installing the lift? you can easly do a BL yourself, all you have to know is how to turn a wrench and operate a floor jack. Its really not more dangerous to have a taller BL, but its just not great for it, the stress on the bolts is the only thing that worries me. all you are doing is putting plastic pucks in between the body mounts, if you do a 3' BL then your bolts are going to be 3' longs = more prone to breaking
Huk
Mar 7, 2012 12:03 PM
604x4
Mar 2, 2012 10:27 AM
Huk
Mar 1, 2012 07:55 AM
russell
Jan 20, 2009 06:37 PM
peterline
Mar 9, 2007 07:02 PM
