misfire
Old May 23, 2008 | 06:11 PM
i_amso_lucky's Avatar
Default misfire
hi i have a 2003 ford f150 . i put it on computer and it game me the code for misfire on cyl 2 i was woundring what could cause it and shes a lil jerky
thanks brian
Old May 23, 2008 | 07:07 PM
Bullitt94's Avatar
Default RE: misfire
Have you tried anything to begin with? If not, start simple with spark plugs.
Old May 23, 2008 | 08:31 PM
oldtimer35's Avatar
Default RE: misfire
This should be a coil on plug motor. I would replace the spark plug, but also the coil boot, as it acts like a bad plug wire. You can buy them separate from the coil and they just pull off the coil and slip back on. The run between 12 and 20 bucks for the boot and the plug is about 7.
Old May 23, 2008 | 08:41 PM
Default RE: misfire
i tried new plugs and boots,,, im think its the coil because im getting the same code4 po302
Old May 24, 2008 | 08:13 AM
BlueOvalFitter's Avatar
Default RE: misfire
What engine is in the truck?
Old May 24, 2008 | 10:41 AM
Default RE: misfire
5.4 v8
akmdiamond
Dec 15, 2005 01:56 AM
mystiquegoddess
Sep 27, 2005 06:54 PM
Blueberry
Sep 2, 2005 01:31 PM
danimal93c
Aug 21, 2005 10:38 PM
Swine
Aug 4, 2005 02:57 PM
