Need help with 2000 f150 transmission
Old Jun 25, 2010 | 10:08 AM
fishndude's Avatar
Default Need help with 2000 f150 transmission
I have a 2000 F150 with a triton 5.4 and a 4spd OD automatic transmission that lost reverse. I have been trying to figure out what trans I have in my truck as I only have the casting numbers, the trans tag is missing. The numbers cast on the side are RF F7AP-7006-AA, there is a W on the tailshaft housing, and the pan says metric with 14 bolts and is mostly square. If i can figure out what this is I can find a replacement or alternate. I have looked on line for casting decoders but they all seem to stop with manufacturing up to 1999 and I havent seen anything with numbers even close to what I have. Any help will be greatly appreciated.
Old Jun 25, 2010 | 11:40 PM
Welcome to the site..
It should be a 4R70W
Should you ever need to ID a trans, look at the VC (vehicle certification) label in the driver door jamb.. Trans code is under 'TR' to the right of Axle.. Yours would be a U code..
strand02
Mar 7, 2011 08:25 AM
Michael Deange
Mar 9, 2009 09:04 PM
birdeeshot
Jan 20, 2006 12:28 AM
birdeeshot
birdeeshot
