neeed some help quickly please (pitman arm seal)
Old Aug 14, 2011 | 06:47 PM
  #11
Its done with the adjustment sleeves.. They look like a 'split' collar with 2 lock bolts, one at each end.. The adjustment screw/nut on the box is for the gear lash adjustment.
Old Aug 14, 2011 | 09:28 PM
  #12
brokentierod's Avatar
okay so straightening the wheel should be fairly easy provided nothing else is wrong with what i did? shouldnt be more then an hour or so shop time?
Old Aug 15, 2011 | 09:29 PM
  #13
okay so 40 dollar seal has now turned into almost 700 dollars...new seal new pitman arm, new left and right upper control arms, new left and right outer tierod ends, and tomorrow an alignment...
guy at the shop says the 1/4 turn of play in the wheel is typical for raybestos pitman arm install and will easily be re aligned during front end alignment.
Old Aug 17, 2011 | 10:23 PM
  #14
thanks for all the help guys, truck drives, handles and brakes like an indy car now..
rebar
May 12, 2013 04:11 PM
rymnryan
May 13, 2009 07:00 PM
shovelups
Dec 21, 2008 10:28 AM
smkave
Nov 9, 2007 08:11 AM
