Noise from under the hood
Old Sep 3, 2020 | 08:23 AM
lariatf150's Avatar
Default Noise from under the hood
Does anyone know if this noise is a belt or pulley only makes the noise in the morning and when accelerating but as the day goes on it goes away.
Old Sep 3, 2020 | 09:21 AM
scott.butler4's Avatar
You need to say what year and engine do you have.
Old Sep 3, 2020 | 09:33 AM
lariatf150's Avatar
It is a 2016 f-150 lariat 5.0
Old Sep 3, 2020 | 12:16 PM
Ohh this is you with the engine replacement.
Start vehicle, open hood, take long screw driver end on pulley bolts that do not rotate, for ones that rotate put screw driver on closest non moving part. Put ear on handle end of screw driver, see where noise is loudest. You can also put the screw driver against the engine case to listen to engine sounds. Sometimes non OEM belts make noise. Using the screw driver is a cheap version of a mechanics stethoscope.
Since they just replaced your engine you could bring it back and let the dealer deal with this and I do not think you would have a deductible.
Old Sep 3, 2020 | 02:07 PM
lariatf150's Avatar
they said that there going to replace the ac belt and serpentine belt. Since it only does it in the morning and gets better as the engine heats up. They actually had to replace all the timing in the engine they installed I didn’t pay for anything. I didn’t even have to pay my deductible.
Old Sep 24, 2020 | 04:52 PM
lariatf150's Avatar
now I have this noise not sure what it is does it on cold starts but then goes away once engine warms up. Here’s the link to the video.
f-150-silver
Oct 25, 2018 05:40 PM
ToxiccKiwii
Jun 23, 2012 02:46 PM
drummerboy70
Aug 26, 2011 09:24 AM
summerson1
Oct 27, 2010 11:02 AM
mathew816
Nov 9, 2008 02:42 PM
