overdrive
Old Mar 21, 2007 | 10:37 PM
kdillon's Avatar
Default overdrive
my overdrive does not work. it wont kick in or anything. any advice anybody?
Old Mar 21, 2007 | 10:49 PM
Default RE: overdrive
I read in one of your other posts that the O/D light does cycle..Correct? What engine?
Old Mar 22, 2007 | 01:51 AM
goinstrong's Avatar
Best advice - don't open the trans. yourself to try to see the overdrive unless you're itching to see God early. If it's not a bad or missing vacuum line and the trans. fluid and filter have been changed recently and your downshift cable? (these used to be a lever - not sure but don't think they still are) isn't stuck or jamming then you may want to call a transmission place/garage that has the tool to disassemble OD trannys (should the spring be damaged).
jklingel
Dec 7, 2007 12:22 AM
tsmith
Mar 21, 2007 10:35 PM
Jojosdad
Mar 14, 2006 08:33 PM
canadianbacon
Jan 30, 2006 04:00 PM
F350powerhorse
Aug 13, 2004 03:02 PM
