Parasitic drain
Ok .. The Parasitic drain came from an abundance of problems along with the new radio being wired correctly. Now is all ok. I have the 2nd battery all wired in and all is working just fine now with no starting problems. I also found that under the passengers side under the carpet was all wet so I removed it and found that all the wiring was sitting in a puddle of water .. removed the wiring and dried them off and wala no more drain. They must have been slowly shorting out. I repaired the drain plug in the floor so it stays dry now. Thanks for all your help in this matter as I would have pulled my hair out with out yas... Haypower...tks again.
