Parasitic drain
Old Dec 24, 2018 | 12:07 PM
F150-07-4.6's Avatar
Default Parasitic drain
Ok .. The Parasitic drain came from an abundance of problems along with the new radio being wired correctly. Now is all ok. I have the 2nd battery all wired in and all is working just fine now with no starting problems. I also found that under the passengers side under the carpet was all wet so I removed it and found that all the wiring was sitting in a puddle of water .. removed the wiring and dried them off and wala no more drain. They must have been slowly shorting out. I repaired the drain plug in the floor so it stays dry now. Thanks for all your help in this matter as I would have pulled my hair out with out yas... Haypower...tks again.
ProStreetDriver
Mar 2, 2017 02:29 PM
easyrydr
Apr 17, 2014 09:26 PM
rzrback1992
Mar 24, 2012 06:30 PM
dee004
Apr 21, 2007 05:23 PM
flamingitaur
Feb 3, 2007 06:44 PM
