Possible tranmission issue or dirty fuel system??
Old Jul 5, 2009 | 05:12 PM
zaroslinski's Avatar
Angry Possible tranmission issue or dirty fuel system??
We have taken our 2005 Ford F-150 Crew Cab Lariat Edition (automatic) in to have the transmission and fuel system checked and they gave us the thumbs up for both.
We are not sure what is causing our issue, but here is the case. When our truck is in overdrive and you gradually step on the gas there is a hesitation. It feels as though the transmission is slipping. For example, if we are cruising on the highway and want to speed up by about ten miles an hour gradually it will create this issue. Once the vehicle is taken out of overdrive it appears to be fine. Every once in a while it will stop hesitating and feel as though the truck has a tremendous amount of power (feels like the gas pedal on a brand new truck). This truck has 68,000 miles on it currently. I am not sure what other information you might need, but please ask if there is any more that you would need. This is frustrating since the Ford dealer tells us there is nothing wrong. I have been driving trucks/cars for years, and this is not normal. Does anyone have any information or could you possibly shed some light on this. Any suggestions are appreciated. Thanks!
Old Jul 7, 2009 | 09:02 AM
Bullitt94's Avatar
First thing I'd try is a basic tune-up (plugs and fuel filter). At the same time, I'd run some Sea Foam in the gas tank. This should eliminate the dirty fuel or missing spark that could be causing this.
Old Jul 11, 2009 | 05:37 PM
3leafclover's Avatar
Default ideas
i have an 03 that does the same thing a couple of things i was told it could be is cat. converter, plugs or maybe the timing ive changed the fuel filter ad used some gumout and still have it
Old Jul 13, 2009 | 05:23 PM
Well, we took it in again and it threw a code for the coil. It had a bad coil so we are having it repaired and get it back today. Hopefully it will drive like a new truck again.
fordborn
Oct 13, 2011 03:52 PM
mashersixone
Sep 5, 2010 04:49 PM
shovelups
Dec 21, 2008 10:28 AM
1meansrt
Apr 7, 2008 09:50 PM
VegasBob
Nov 10, 2006 02:39 PM
