problematic 97
Old Jan 6, 2008 | 05:49 PM
cordesr1's Avatar
Default problematic 97
i have a 97 f150 with the 4.6L V8. the engine seems to be missing at low rpms. after a few second of the rough running the check engine lite starts flashing. also after about 20 min of running down the highway the overdrive off light stats flashing. if i hit the od off button the truck will run with od off but the light still flashes.
the last problem is not so major but still is enough to make me mad. the truck has the 6 disk changer with the changer next to the back seat. somehow the changer has eaten the cartridge. if it hit cd on the radio it reads no disk and when i hit the eject button it does not give the cartridge back
any help would be greatly appriciated
Old Jan 6, 2008 | 10:11 PM
btexpress's Avatar
Default RE: problematic 97
First thing you need to do it get the vehicle checked for codes.......this is the only way to find out why those lights are on.
The CD changer probably has something stuck in it, coins, or anything that could fall in there or get slipped in by children who don't know what foreign objects do to cd changers. I have also found many times two cds stuck in one slot, it can happen easily.
Old Jan 7, 2008 | 12:24 PM
Bullitt94's Avatar
It may say in your manual what the flashing lights mean.
I agree that getting the codes checked would be a good first move.
Old Jan 7, 2008 | 04:52 PM
oldtimer35's Avatar
The flashing ck engine lite means you have a misfire that is detremintal to the catalytic convertor and the pcm will shut off the injector to that cylinder. This is something that needs to be addressed post haste, as the cost of a catalytic convertor is not cheap, and not covered under your emissions warranty.
The od lite might be linked to the ck engine lite as the engine is not producing the power it should and this effects transmission operation.
As for the cd cartridge, you probably have something stuck in it, along with the cartridge.
Old Jan 14, 2008 | 03:26 PM
illegalimmigrant's Avatar
ITS A FORD
FOUND ON ROAD DEAD
FIX OR REPAIR DAILY
F*CKED ON RACE DAY[:-]
Old Jan 15, 2008 | 08:36 AM
Bullitt94's Avatar
ORIGINAL: illegalimmigrant
ITS A FORD
FOUND ON ROAD DEAD
FIX OR REPAIR DAILY
[sm=icon_blah.gif]
Thanks for that.
