radio not working
Old Oct 9, 2020 | 09:55 AM
odarmedinacoronel's Avatar
Default radio not working
under dashboard fuse box fuses # 20 and 21 no power all fuses were good including fuse box in the engine compartment also relays were good my question what are the possible solution before i buy a new radio by the way my truck is 1999 ford f-150 lariat 5.4l
Old Oct 9, 2020 | 11:05 AM
scott.butler4's Avatar
Here is the radio wiring diagram and connector face, remove the radio, check for continuity and voltage for both the power and ground wires, I circled power pins in red and ground pins in blue.
Make sure the key is in the correct position when you check the power wires. Let me know if you need specific instructions on how to complete this electrical diag.
Jonb8
May 11, 2017 02:19 PM
Randy Raines
Dec 17, 2012 05:46 PM
dkimbro
Aug 31, 2009 07:49 AM
txhessranger
Sep 18, 2008 06:27 PM
tdknott
Feb 17, 2008 03:39 PM
