rear end gears
Old Jan 2, 2009 | 09:28 AM
BPapa28's Avatar
Default rear end gears
I have a 99 f-150 4x4 and the gears in my rear end just broke on me. I am wanting to know if I could put 4:10's in without any problems, and how hard is it? thank for any help!
Old Jan 2, 2009 | 06:02 PM
way2old's Avatar
Default RE: rear end gears
You can put the 4:10's in it, but, you will need a different speed sensor gear. If not your speedometer and odometer will not be correct. It may also cause other things to not work as designed.
Old Jan 2, 2009 | 10:13 PM
BPapa28's Avatar
With the spider gears broke would it be easier to change the gears or just swap out the rear end with 4:10's already set up, also will that screw up my 4x4 system?
Steve Brisbois
Mar 25, 2020 11:44 AM
russell_j2003
Mar 25, 2020 11:39 AM
elkahalic1
Jan 19, 2014 01:29 PM
Dan Smithwick
Jul 19, 2009 08:25 AM
CaptJack101
Mar 12, 2008 12:30 AM
