Rear Seats a good ground for subwoofer?
Old Dec 4, 2020 | 09:59 AM
Stephen Thompson's Avatar
Default Rear Seats a good ground for subwoofer?
So a little context before I ask my question.
I'm in the market for a compact subwoofer since I drive a 2003 ford f150 lariat and I was going to put it under my rear seats and I've already got an idea as to how connect it to the battery and all that. However there is a small problem, I don't know where a good ground connection would be. My question is this, is there anywhere under the rear seats that would be a good ground for a subwoofer or are the brackets that connect the seats to the floor a good ground?
Old Dec 5, 2020 | 05:59 AM
scott.butler4's Avatar
Ground is ground is ground.
Use a wire brush/flap wheel to remove paint on the frame/body of where the ground ring terminal will go, install the bolt with the correct sized ring terminal on it.
The frame is used as a ground for most everything else already, as long as you remove the paint so it gets the best contact patch possible you are good to go.
Zipur
Nov 25, 2018 05:10 PM
McStein
Sep 22, 2018 01:26 PM
kc2121
May 5, 2010 02:24 PM
txhillbilly
Nov 9, 2009 07:46 PM
rangerfx4l2
Oct 21, 2006 11:22 PM
