rear spring shackle
Old Apr 3, 2007 | 12:59 AM
joeski's Avatar
Default rear spring shackle
my '97 flareside rear shackle is really rotted & I was told this was a common problem. My '88 bronco II looks like it's still new. They both have similar mtg. brackets except different orientations-the springs attach to the bottom shackle on the bronco II & the top of the 150.Could this bracket or one similar be used on the F-150 or could its bracket be flipped?
Old Apr 3, 2007 | 09:20 PM
Bullitt94's Avatar
Default RE: rear spring shackle
I'm not sure if those are the same or not, but it sounds like you're looking for a cheap fix. If that's the case, call your local junk yard and buy one from them.
Old Apr 4, 2007 | 02:23 AM
goinstrong's Avatar
I agree - it would be safer to check the salvage yard to start. If they are identical (height, width, metal thickness, orientation of holes and angles) I'd say there is a fair possibility it might work if it's absolutely necessary.
Old Apr 4, 2007 | 02:24 AM
goinstrong's Avatar
Only a hollander interchange manual knows for sure - call a salvage yard for themanual nearest you.
Dan Smithwick
Aug 4, 2009 01:52 PM
arosen999
Aug 23, 2007 01:54 AM
billj818
Nov 18, 2006 09:27 PM
94 exp
Sep 26, 2006 10:22 PM
engrjohn
Oct 5, 2005 10:54 PM
