Removing Serpentine Belt on 1999 V-6
Old Mar 26, 2007 | 11:35 PM
northman's Avatar
Default Removing Serpentine Belt on 1999 V-6
My dad has a 1999 Ford F-150 with a V-6. The serpentine belt needs to be replaced. Now I changed one on my Ranger and there was a 3/8th square on the tension arm that you can put a ratchet or breakbar in to take the tension off the belt and replace it. I don’t see that on this vehicle. How is the tension taken off to remove the belt? Any help would be appreciated.
Thanks!!!
Old Mar 26, 2007 | 11:39 PM
Default RE: Removing Serpentine Belt on 1999 V-6
Is this a 4.2?
Old Mar 26, 2007 | 11:55 PM
northman's Avatar
He's not sure but I believe that it is. I think it was the only V-6 in 1999 for the F-150.
Old Mar 27, 2007 | 12:35 AM
Sorry... Missed that part of your post (V6) and read only about the 'no hex' in the tensioner.. thats why I assumed a V6.. Been a LONG day! For the 4.2 put a wrench on the tensioner/idler and rotate it to release the tension....
[IMG]local://upfiles/6756/B5A2F3C3B17A4C6985C1A6444FA0C490.gif[/IMG]
Old Mar 27, 2007 | 01:06 AM
northman's Avatar
Thanks for your help. I feel foolish aboutasking a question like this anyway. When engines just had fan belts and an adjutment it was much simplier. Any way I did put a socket and breakbar on the tensioner and it wouldn't budge.Yep i was turning it in the correct direction.It did seem that the boltmoved some but the tensioner didn't move.I sprayed some LPS II on the spring tensioner hopefully it will losen it up some. I fear that the tensioner is rusted stiff.
Old Mar 27, 2007 | 01:12 AM
Should be able to grab the belt and give it a tug.. You should see the tensioner rotate some.. Or pull 'up' on the belt and try and rotate the tensioner at the same time to gain enough slack to pull the belt....
Old Mar 27, 2007 | 04:23 PM
goinstrong's Avatar
Don't be afraid to put a little oompfh into it. The breaker bar should help though.
54ford
Sep 14, 2011 10:39 PM
Tashamay
Mar 19, 2007 03:14 AM
mhaggitt
Feb 13, 2007 01:53 AM
scaaar
Sep 2, 2006 03:12 AM
Ritehsedad
May 14, 2005 11:28 AM
