Running Too Rich
Old Oct 9, 2005 | 07:53 PM
fordgirl2's Avatar
Default Running Too Rich
Help!! My 92 F150 fuel injected truck is running way too rich. There is the smell of fuel in th oil. After hooking up a computer to it, I changed the oxygen sensor and egr sensor according to the codes. There is a beautiful black spray that comes out of the exhaust system when I start the truck. ( it looks nice all over my white car that sits next to the truck)
Any suggestions? Anyone know where I can get a good diagram of the fuel system?
Old Oct 9, 2005 | 10:20 PM
rusty ol ranger's Avatar
Default RE: Running Too Rich
Fuel in the Oil?
Im betting on a fuel pressure regulator.
later,
Dustin
Old Oct 10, 2005 | 12:37 AM
hockeyhitman69's Avatar
yeah check you fuel pressure bet it real high
Old Oct 10, 2005 | 08:15 PM
fordgirl2's Avatar
okay..where I have been told i need a special pressure tester for that...any information on that?
Thanks for your replies..much appreciated
Old Oct 10, 2005 | 09:41 PM
Yeah, you need a fuel pressure testing set.
You can get them at autzone for like 15 bucks.
later,
Dustin
Old Nov 24, 2005 | 08:04 AM
fordgirl2's Avatar
[sm=thanx.gif]Thank you thank you thank you..I was heading to the parts store to get a fuel pressure regulator, when the transmission went out on the truck. That major issue got me sidetracked from the driveability problem for the last three weeks. Once the "certified ford technichian" rebuildt the tranny, we got back to the fuel issue. As I insisted we needed to change the F.P.R. he insisted we didn't. I won although he made me do it myself..which was easy..and TADA.. problem solved.
Thanks to you for answering my post, and giving me bragging rights.
Thanks again
Kat
Old Nov 25, 2005 | 05:16 AM
Ramrod48's Avatar
Normally when the fuel pressure reg. goes out , If you pull the lil vacumm hose off the nipple .
An with the engine running it will shoot fuel up outta the nipple.
So dont get your face real close to it when you do. the engine vaccum ends up sucking the
fuel into the motor an it ends up in the oil pan, not good, glad you got it fixed
drunkn_moose
Apr 23, 2008 10:24 PM
greuelc
Dec 22, 2007 03:23 PM
jeffandteneka
Feb 16, 2007 09:58 AM
bytesnooper
Jun 13, 2005 08:35 AM
bytesnooper
Jun 11, 2005 01:13 PM
