shudder at 40-50 mph
Old Jan 16, 2008 | 11:17 PM
jokerjac's Avatar
Default shudder at 40-50 mph
97 f150 4.6 4r70w tranny. started to shudder at about 45 mph. got bad and parked it. got another tranny. after install still does it. will not do it if I continue to accelerate past the 40-45mph zone. if driving at say 40 mph and try to accelerate gradually (normal driving) it shudders. If I am driving below 40 mph and accelerate more rapidly to say 55mph it does not shudder at all. PLEASE HELP?
Old Jan 17, 2008 | 08:56 AM
Bullitt94's Avatar
Default RE: shudder at 40-50 mph
Does it do it only when on the gas? If so, check u-joints.
If it does it coasting or while on the gas, then you may have lost a weight on your wheel and they need balancing.
If not either of those, park it in a dark garage and rev the engine. You may see spark jump from the plug wires. If so replace the wires.
I'd start there. Eliminate the cheapest things first.
Old Jan 17, 2008 | 01:01 PM
jokerjac's Avatar
It only does it when accelerating but the U-joints seem fine. If I let up on the accelerator the shudder stops. I have not thought about the plugs but I do not have a garage to get it in. I think that I will just change the plugs and the wires. To be honest, the truck could probubly use them either way. Let you know hoe it goes. And thanks for the reply.
Old Jan 17, 2008 | 02:59 PM
Bullitt94's Avatar
You can just do it at night, too.
Let us know how it goes. Good luck.
Old Jan 19, 2008 | 02:41 PM
jokerjac's Avatar
Bullitt94- I changed the plugs and lo and behold the problem is gone!!!!! The truck has never run better since I have owned it. Thank you so much for your input on this problem.
Old Jan 21, 2008 | 09:11 AM
Bullitt94's Avatar
No problem. Enjoy the ride!
94escortlxer
Jul 14, 2007 01:49 PM
jbrink
Apr 23, 2007 01:22 PM
Ram1500dodge
Apr 9, 2007 01:05 AM
treytroxell
Feb 1, 2006 11:02 PM
treytroxell
Jan 23, 2006 06:01 PM
