Speed Adjustment
Old Mar 24, 2009 | 08:54 PM
caguas56's Avatar
Unhappy Speed Adjustment
Hi everyone, I need info on how to get the right speed readout from my speedometer. I have a F-150 2006 4.2 engine with 5 speed manual transmission with a 17" factory wheels and a 355 rear axle and changed the rear axle with a 308 8.8. my speed is reading about 5 miles below what used to be.
What do I need to get the right speed reading?
thanks in advance
Jorge Gonzalez.
Old Mar 25, 2009 | 12:32 PM
Bullitt94's Avatar
Some programmers let you adjust the speedometer, but I have never used one to tell you the details exactly.
Old Mar 25, 2009 | 06:14 PM
way2old's Avatar
Check with your local dealer to see what gear that goes with the 3.08 gears. It should beas simple as removing the VSS and replacing the plastic gear.
Old Mar 27, 2009 | 12:45 PM
JTGrant1's Avatar
you can probably just hook it up to a good scan tool, and change it. Theres quite alot that you can do with them now-a-days. It wouldnt be to bad if you took it to a dealer and had them do it for you either.
makuloco2000
Nov 23, 2013 10:38 PM
makuloco2000
Nov 23, 2013 10:37 PM
makuloco2000
superdavefarmer
Feb 22, 2008 08:50 PM
abaca
Apr 18, 2005 03:05 AM
