timing
Old Jul 7, 2007 | 06:54 AM
sdpuff's Avatar
Default timing
i have a 87 150 4.9 i bought from a friend and when i went to set the timing i put the #1 cyl at tdc compression and the notch in the crank pulley was at 6 o'clock at the bottom no where near the timing mark plate does anyone know why? doesnt make sense it should be at the tdc mark on the timing plate shouldnt it!!!!
Old Jul 9, 2007 | 12:58 PM
ky_ace's Avatar
Default RE: timing
Sounds like you should look at a repair manual, make sure you have the correct "#1" piston. Set it at TDC, drop in the distributor with the rotor button facing the correct wire that corresponds with the #1 piston, and fire it up. I dont know how it works exactly, but maybe your harmonic balancer is in the wrong spot (rotation wise)
NickTurbo
Apr 1, 2012 09:21 AM
FIRE RANGER
Dec 6, 2009 01:17 PM
Qaiphyx
Apr 4, 2008 11:59 AM
DRLM002
Aug 28, 2007 07:33 PM
Rayshawn
Oct 26, 2006 12:01 AM
