torque specs
Old Jun 11, 2017 | 04:48 PM
Jennifer Kauffman's Avatar
Default torque specs
I need the torque specs for a 1998 f 150 4.2 liter v-6... Can you help
Old Jun 11, 2017 | 11:18 PM
Thumbs up
Welcome to the site..
Complete engine tightening torque specs?
Old Jun 14, 2017 | 08:50 PM
Default Torque specs
Yes please
Old Jun 14, 2017 | 11:34 PM
Engine Torque Specifications
Torque Specifications for Ford 4.2L-256ci-V6
Connecting Rod To Crankshaft
29 Ft-Lbs
348 In-Lbs
39.32 N-m
Years: All
Note: Essex 90deg - Rod Cap - 2 Steps: 29FtLbs; +90deg
Type: Dim: Length: Head: Grade:
Crankshaft To Engine Block
88 Ft-Lbs
1056 In-Lbs
119.31 N-m
Years: All
Note: Essex 90deg - Main Cap - 1, 2, 3
84 Ft-Lbs
1008 In-Lbs
113.89 N-m
Years: All
Note: Essex 90deg - Main Cap - Rear
Cylinder Head To Engine Block
14 Ft-Lbs
168 In-Lbs
18.98 N-m
Years: All
Note: Essex 90deg - STEP 1: 14 FtLbs
Type: Bolt Dim: Length: Head: Hexagon Grade:
29 Ft-Lbs
348 In-Lbs
39.32 N-m
Years: All
Note: Essex 90deg - STEP 2: 29 FtLbs
36 Ft-Lbs
432 In-Lbs
48.81 N-m
Years: All
Note: Essex 90deg - STEP 3: 36 FtLbs
33 Ft-Lbs
396 In-Lbs
44.74 N-m
Years: All
Note: Essex 90deg - STEP 4: LONG Bolts Loosen 3 Turns; 33FtLbs
19 Ft-Lbs
228 In-Lbs
25.76 N-m
Years: All
Note: Essex 90deg - STEP 4: SHORT Bolts Loosen 3 Turns; 19FtLbs
0 Ft-Lbs
0 In-Lbs
0 N-m
Years: All
Note: Essex 90deg - STEP 5: ALL Bolts - +180deg
Drain Plug To Oil Pan
11 Ft-Lbs
132 In-Lbs
14.91 N-m
Years: All
Note: Essex 90deg - Oil Drain Plug
EGR Valve To Intake Manifold Plenum
16 Ft-Lbs
192 In-Lbs
21.69 N-m
Years: All
Note: Essex 90deg - EGR Valve to Intake Plenum
Engine Block To Transmission
38 Ft-Lbs
456 In-Lbs
51.52 N-m
Years: All
Note: Essex 90deg - Transmission to Engine Block Bolts
Exhaust Manifold To Cylinder Head
18 Ft-Lbs
216 In-Lbs
24.4 N-m
Years: All
Note: Essex 90deg - Exhaust Manifold Bolts
Exhaust Pipe To Exhaust Manifold
30 Ft-Lbs
360 In-Lbs
40.67 N-m
Years: All
Note: Essex 90deg - Exhaust Pipe to Exhaust Manifold Bolts
Fan Blade To Fan Clutch
13 Ft-Lbs
156 In-Lbs
17.63 N-m
Years: All
Note: Essex 90deg - Fan Assembly to Fan Clutch Bolts
Fan Blade Housing To Radiator
7 Ft-Lbs
84 In-Lbs
9.49 N-m
Years: All
Note: Essex 90deg - Fan Shroud to Radiator
Fan Clutch To Water Pump
41 Ft-Lbs
492 In-Lbs
55.59 N-m
Years: All
Note: Essex 90deg - Fan Clutch to Water Pump
Flywheel To Crankshaft
60 Ft-Lbs
720 In-Lbs
81.35 N-m
Years: All
Note: Essex 90deg - Flywheel/Driveplate Mounting Bolts
Fuel Rail To Intake Manifold
8 Ft-Lbs
96 In-Lbs
10.85 N-m
Years: All
Note: Essex 90deg - Fuel Rail Mounting Bolts
Intake Manifold To Cylinder Head
8 Ft-Lbs
96 In-Lbs
10.85 N-m
Years: All
Note: Essex 90deg - 2 Steps: 4FtLbs; 8FtLbs - Lower Manfold
Intake Manifold Plenum To Intake Manifold
4.92 Ft-Lbs
59 In-Lbs
6.67 N-m
Years: 1997-2000
Note: Essex 90deg - Air Intake Plenum Mounting Bolts
7.5 Ft-Lbs
90 In-Lbs
10.17 N-m
Years: 2001-2002
Note: Essex 90deg - Plenum Bolts - 2 Steps: 5.5FtLbs; 7.5FtLbs
7.5 Ft-Lbs
90 In-Lbs
10.17 N-m
Years: 2001-2002
Note: Essex 90deg - Spacer Bolts - 2 Steps: 5.5FtLbs; 7.5FtLbs
Oil Pan To Engine Block
8 Ft-Lbs
96 In-Lbs
10.85 N-m
Years: All
Note: Essex 90deg - 2 Steps: 3FtLbs; 8FtLbs
Oil Pan To Transmission
33 Ft-Lbs
396 In-Lbs
44.74 N-m
Years: All
Note: Essex 90deg - Oil Pan to Transmission Bolts
Oil Pump To Timing Chain/Belt Cover
7 Ft-Lbs
84 In-Lbs
9.49 N-m
Years: All
Note: Essex 90deg - Oil Pump/Filter Body to Front - 6mm Bolts
Type: Bolt Dim: M 6 X 1.00 Length: Head: Hexagon Grade:
18 Ft-Lbs
216 In-Lbs
24.4 N-m
Years: All
Note: Essex 90deg - Oil Pump/Filter Body to Front - 8mm Bolts
Type: Bolt Dim: M 8 X 1.25 Length: Head: Hexagon Grade:
Power Steering Pump To Engine Block
18 Ft-Lbs
216 In-Lbs
24.4 N-m
Years: All
Note: Essex 90deg - Power Steering Pump Mounting Bolts
Pressure Plate To Flywheel
42 Ft-Lbs
504 In-Lbs
56.94 N-m
Years: All
Note: Essex 90deg - Pressure Plate to Flywheel Bolts
Pulley To Vibration Damper/Hub
24 Ft-Lbs
288 In-Lbs
32.54 N-m
Years: All
Note: Essex 90deg - Crankshaft Pulley to Vibration Damper
Pulley To Water Pump
19 Ft-Lbs
228 In-Lbs
25.76 N-m
Years: All
Note: Essex 90deg - Water Pump Pulley to Water Pump
Rocker Arm To Cylinder Head
26 Ft-Lbs
312 In-Lbs
35.25 N-m
Years: All
Note: Essex 90deg - Rocker Arm Fulcrum Bolts
Spark Plug To Cylinder Head
10 Ft-Lbs
120 In-Lbs
13.56 N-m
Years: All
Note: Essex 90deg - Spark Plug
Type: Dim: Length: Head: Hexagon Grade:
Thermostat Housing Cover To Thermostat Housing
8 Ft-Lbs
96 In-Lbs
10.85 N-m
Years: All
Note: Essex 90deg - Thermostat Housing Bolts
Throttle Body To Intake Manifold Plenum
8 Ft-Lbs
96 In-Lbs
10.85 N-m
Years: All
Note: Essex 90deg - Throttle Body Mounting Nuts
Type: Dim: Length: Head: Nut Grade:
Thrust Plate To Engine Block
8 Ft-Lbs
96 In-Lbs
10.85 N-m
Years: All
Note: Essex 90deg - Balance Shaft Thrust Plate Bolts
8 Ft-Lbs
96 In-Lbs
10.85 N-m
Years: All
Note: Essex 90deg - Camshaft Thrust Plate Bolts
Timing Chain/Belt Cover To Engine Block
18 Ft-Lbs
216 In-Lbs
24.4 N-m
Years: All
Note: Essex 90deg - Timing Chain Cover to Engine Block Bolts
Timing Chain/Belt Sprocket To Camshaft
33 Ft-Lbs
396 In-Lbs
44.74 N-m
Years: All
Note: Essex 90deg - Camshaft Sprocket Bolt
Valve Cover To Cylinder Head
8 Ft-Lbs
96 In-Lbs
10.85 N-m
Years: All
Note: Essex 90deg - Valve Cover Bolts
Vibration Damper/Hub To Crankshaft
110 Ft-Lbs
1320 In-Lbs
149.14 N-m
Years: All
Note: Essex 90deg - Vibration Damper Bolt
Water Pump To Engine Block
19 Ft-Lbs
228 In-Lbs
25.76 N-m
Years: All
Note: Essex 90deg - Water Pump to Engine Block BOLTS
5.5 Ft-Lbs
66 In-Lbs
7.46 N-m
Years: All
Note: Essex 90deg - Water Pump to Engine Block NUTS
Water Pump To Timing Chain/Belt Cover
18 Ft-Lbs
216 In-Lbs
24.4 N-m
Years: All
Note: Essex 90deg - Water Pump to Timing Chain Cover Bolts
Old Jun 14, 2017 | 11:47 PM
FordAmers
Feb 17, 2009 02:36 AM
FordAmers
Jan 12, 2009 09:31 AM
90ranger
Nov 3, 2007 03:25 PM
tsi18psi
Sep 27, 2007 07:48 PM
scottngio
Oct 31, 2006 03:07 AM
