transmission swap for f150
Ok i have a 1997 f-150 2wd with the 4.6 liter but it needs a new transmission and i found a 1994 ford thunderbird for cheap and it comes with the 4.6 liter engine. I was wondering if i could take the transmission out of the thunderbird and put it on my f-150, is that possibe?
If it's the same 4R70W trans, it should work fine. The electronics are the same, as is the logic. However, some of the trucks from this generation were equipped with the E4OD trans, which is bigger and has a different connector, cooler lines, etc, etc.
danowens
Nov 14, 2006 10:59 AM
