Turbo removal
How do I remove and replace my driver side turbo on my 2015 f150 2.7 v6
Turbocharger LH RemovalNOTICE: Whenever turbocharger air intake system components are removed, always cover open ports to protect from debris. It is important that no foreign material enter the system. The turbocharger compressor vanes are susceptible to damage from even small particles. All components should be inspected and cleaned, if necessary, prior to installation or reassembly. NOTE: Some turbos are equipped with a heat shield, heat shields were deleted and some service turbos will not have mounting bosses for the heat shield.
WHEN THE INSTRUCTIONS SAY TO TORQUE THE NUTS IN A SPECIFIC ORDER DO SO IN THAT GODDAMN ORDER.
Installation NOTICE: Make sure that the mating faces are clean and free of foreign material. NOTE: Some turbos are equipped with a heat shield, heat shields were deleted and some service turbos will not have mounting bosses for the heat shield.
Thank you sir
Got my turbo off thanks for the help
