Water in Cab!
Old Jul 29, 2006 | 03:31 AM
roadhouse1301's Avatar
Default Water in Cab!
I have a leak on my 03 F-130. A big enough leak that it filled up the channel above the rocker panel where the wiring passes to the rear of the cab under the floormat. Further inspection has revealed the water appears to be coming through the firewall just above the passenger side floormat. There is a plastic piece that looks like it passes through the firewall on the left side of the passenger floor pan possibly going to the fresh air plenum. This piece has a foam gasket around it that is sopping wet. Has anyone else experienced this problem? The truck has never seen mud so I assume nothings clogged.
Thanks for any light you can shed.
Old Jul 30, 2006 | 12:53 AM
Mulletman's Avatar
Default RE: Water in Cab!
There is a Ford TSB about water coming in from the "A" pillars, but nothing found on a water leak concern where you see it. Double-check and make sure there is no water coming in from the "A" pillars an then seeping down to where you see it wet. You may have to remove the grab rail and trim to investigate.
RetiredVet96
Nov 24, 2020 04:27 PM
Joe Reeves
Dec 13, 2013 11:43 AM
nabor j
Jan 21, 2012 12:28 PM
CW
Apr 15, 2008 12:05 PM
ktmchick
Feb 11, 2008 09:45 AM
