03" F250 S/D crew cab thumping in front end
Old Apr 24, 2009 | 11:28 AM
ngaspecialties's Avatar
Default 03" F250 S/D crew cab thumping in front end
Hi, I'm trying to help diagnoise a problem my good non mechanically inclined friend is having with his F250. whenever your driving it and hit a small bump at slow or high speeds you here a thump or rattle in the front end like something in lose or worn. you can feel it in the floor boards slightly. i've done some searching and the only other similar sounding problem i saw in another forum was the cab mounting bolts were loose. Also if it makes a difference this truck has about 95K miles on it. thanks in advance
NGA
Old Aug 25, 2009 | 06:31 PM
jakemilo1's Avatar
Default thumping noise in front end
it could be your sway bar bushings on the front end
Old Sep 20, 2009 | 04:59 PM
smallaxe's Avatar
try tightening the shock absorber mounting bolts
Old Sep 25, 2009 | 07:46 PM
Bert's Avatar
Default thumping in front end
try getting your ball-joint check. i have the same thing and had the same problem, new ball-joints no more problem
toddinav
Nov 5, 2012 03:33 AM
mystarcollectorcar
Mar 12, 2010 07:45 PM
chachi
Sep 15, 2008 08:48 PM
