08 V-10 Which Plugs & Coils
Old May 17, 2022 | 08:47 PM
Jsteph's Avatar
Question 08 V-10 Which Plugs & Coils
I recently purchased a 08 King Ranch with a V10, 150k miles. Started having MisFires in three cylinders around 152k and I've read all the threads and possible causes, but here's my dilemma:
According to what I've read the (SP-509) Plugs work with the (DG521) Brown Boot Coils & the (SP-546) are used with (DG511) Black Boots. I get under the hood and find the following.
  1. Someone installed some cheap Chinese knock off coils. (Xaexheart, you can buy all 10 for under $100 on-line) They look like Accel coils with black boots.
  2. I pulled a couple of plugs and they're Motocraft SP-509's which still have the proper gap but you can see a Carbon Track on them
I couldn't find anything definitive that states which Coil & Plug work in an 08, so based on the plugs I'd purchased a new 509 plug with a DG521 Coil (Brown boot), but the Coil has some wiggle room after I tighten it down. Now I'm confused.
  • Is it normal, for a Super Duty coil to have some play, I wouldn't think so? I'm assuming it's because the Brown Boots are too long.
  • If I should be using the Black Boot Coils then do I need to change all the plugs to the 546 or are the Spark Plugs interchangeable? I was able to remove the two plugs easy enough but I'm concerned if the threads were damaged by installing the wrong plugs.
Any help or suggestions will be deeply appreciated
aaknj
Mar 24, 2021 09:09 PM
renegaderob18
Jan 5, 2014 03:17 PM
chuloboy
Jul 23, 2011 09:20 PM
Linus
Apr 13, 2010 06:29 PM
Another Device
Feb 16, 2009 09:41 AM
