1974 points distbutor
Old Aug 6, 2005 | 04:45 PM
kinkydoints's Avatar
Default 1974 points distbutor
I have just changed my old points distributor with a new Mallory magnetic elctronic model 5056701
the instuctions said that i may need a ballist resistor in line from the key switch to the positive side of the coil.
is that circut already have a "resistance type of wire"going to the coil from the key switch?
all the manuals that i have only show a resistor on the electronic ignition models...
Old Aug 7, 2005 | 11:08 AM
Ramrod48's Avatar
Default RE: 1974 points distbutor
the wire does the same thing as the ballast, shoots 12 volts to start , then drops to nine to run ,,
Old Aug 7, 2005 | 12:51 PM
thanks Im just doing as much research as I can .
went to the mrgasket website and found the info from mallory that helped alittle
so a ford has the "loom type " wire in it?
I have gotten a ballist resistor and wired it in and the truck runs poorly off idle
but without the added resistor it runs great!
Thanks again
Old Aug 7, 2005 | 02:40 PM
Ramrod48's Avatar
yeppers , loom type ,,, built in-- not added on , did you expect any less from FORD !!!!!
nickbertozzi
Apr 2, 2010 10:12 PM
Carriage32
Oct 14, 2009 07:08 PM
stclist111
Sep 14, 2009 07:05 AM
Klimzc
Nov 26, 2008 12:55 PM
newguy18
Oct 27, 2007 12:27 PM
