1986 Ford F250 Electric Fuel Pump
Seeking recommendations for reliable electric fuel pump (or preferably the complete sending unit) for rear steel fuel tank.
I have a 1986 Ford F-250 4X4 with 7.5 460 engine. I really want to purchase the complete sending unit with a pump. The obstacle is that I have a steel tank but what is available to purchase is specifically for plastic tanks. I believe that my only option is to purchase just the pump. When I look at other online companies there are various brands (Spectra Premium, US Motor Works). Carter/Airtex does not have the electric pump I need for the rear tank. Do you have a recommendation? Last thing I want to do is go through all this work and get a pump that is junk. |
This is a shot in the dark.
You might try , Vintage Parts Inc. Beaver Dam, Wisc. You might have to buy the entire fuel pump module that comes with the pump and gauge sending unit, Not cheap. |
I just called them and gave them the original part number. They don't carry it. Thanks anyway.
Carter and Airtex are good pumps..
I don't remember any original tanks being plastic, did someone change them? |
It would be my preference to buy a Carter or Airtex but they don't have the electric fuel pump or the complete sending unit for the rear steel tank. They only have it for a plastic tank which is a different size sending unit/pump. Apparently somewhere down line fuel tanks went plastic. I can still buy a rear steel tank but can't buy the sending unit for one. It's frustrating. I just wanted to know if there was an opinion/recommendation of the electric fuel pump brands I mentioned.
If you type in, Fuel pump module for 1989 FORD F-250 and hit search, there are several that might be what you are looking for.
If you have a choice go for the carter or if you can find Delphi, those would be my choice. From experience, I had nothing but issues with Airtex and Spectra electric fuel pumps.Because of availability, you might not have a choice.
