1992 f 350 tranny compatible 6.9 liter
Old Sep 26, 2012 | 04:04 PM
banicman's Avatar
Default 1992 f 350 tranny compatible 6.9 liter
i have a rebuilt 6.9 liter from a 86 f 250. i am putting the rebuilt motor in a 1992 f 350, what class of automatic tranny is compatible. I took out the crappy 351 gas and putting in a real motor, the tranny is my real hold up. thanks for the reply
Old Sep 27, 2012 | 04:16 PM
thexlo8ers's Avatar
The I/N 6.9 liter diesel is at best rated at 170hp, and peak torque at about 335ft.lbs at a very low 1400 rpm's.
A C/6 automatic has more than enough strength to handle these numbers. Look for one from another diesel.
Other things to consider are transmission/transfer case output shaft spline numbers, drive shaft length, and rear axle ratio.
The door code on the '92 will tell you the rear-end ratio. If it's still there, and the rear-end is the same one upon assembly of the truck.
yosef
Jul 20, 2012 04:27 PM
hanksr651
Mar 5, 2010 02:11 PM
txcountrygurl
Sep 17, 2008 05:28 AM
drw0392
Aug 24, 2006 07:42 PM
willy2006
Oct 22, 2005 12:32 AM
