2000 F350 super duty will not go into four wheel drive
Old Jun 22, 2023 | 05:20 PM
Crazy Old Fart's Avatar
Default 2000 F350 super duty will not go into four wheel drive
I have a 2000 F350 Super Duty with On The Fly 4wd that will not go into 4wd, I checked both fuses and found the 30 amp maxi fuse blown, replaced the fuse still no shift, I checked both relays for actuation and just in case replaced said relays.
Connected My Snap-ON Solos Pro and tested the switch, it shows the switch is working, but does not show any shifting
The shifter on the transfer case does actuates when voltage is applied. I can't see any chaffed, broken or grounded wires and I get no voltage at the transfer case.
The wiring diagram shows an Electronic Shift on the Fly solenoid and a four wheel drive control module > My quandary is where do I go from here??
Frank
Old Jul 28, 2023 | 06:29 PM
kiwiinsask's Avatar
mine is the same , have you checked the vacumm that actuates the locks?
Old Jul 28, 2023 | 06:33 PM
A common issue was vacuum pump out by the right battery,, and of curse line/hub vacuum leaks. Will they lock in manually? NON ESOF
Michael Lachowicz
Aug 6, 2020 08:26 AM
Deadeye
Jan 11, 2013 03:04 PM
jhamil25
Nov 2, 2012 05:13 AM
dixiestripes85
May 2, 2010 03:45 PM
2000explorerman
Jul 19, 2008 12:08 PM
