2002 7.3 diesel eng. Will it help milage if I put in a programmer, how much and will it hurt the eng
Old Nov 29, 2006 | 12:36 PM
broncoabe33's Avatar
Default 2002 7.3 diesel eng. Will it help milage if I put in a programmer, how much and will it hurt the eng
Gas Milage 7.3 diesel
Old Nov 29, 2006 | 10:30 PM
Default RE: 2002 7.3 diesel eng. Will it help milage if I put in a programmer, how much and will it hurt the eng
Mileage numbers will/can vary, especially with the 'added' power if you use it or like to 'play'.. The great thing about tuners is that you usually get the extra ponies 'without' any loss of MPG.. The sell is,,, that most tuners should yield you from 1-2MPG more.. My 6.0 is running the Diablo Predator and has been for 20K miles with no problems.. My brother runs the Superchips tuner on his 7.3 also with no issues.. But I don't hammer on mine either.. OK, maybe once in a while if I really need to pass or get in a sticky situation I don't 'really' see any huge improvement in mileage, but most of my driving is commute.. Out on the open highway I always seem to not be able to keep it under 75 or so, and the bigger mileage gains would probably be if you could keep the speed down lower.. These trucks are like pushing a 'brick' through the air, and the faster the speed, equals more resistance, and more throttle.. I think if you were to keep your speed at 65, mileages would increase.. The power gains aren't as steep with a 7.3, in comparison to the 6.0, but it does wake up the beast.. Plus the tuner is a DTC code reader which can be a plus..
Old Nov 30, 2006 | 12:53 AM
thanks for your advice, still will consider getting a programer , like hypertech....thanks....abe
Old Dec 10, 2006 | 03:40 PM
Ben 97's Avatar
An Intake and exaust/straight pipe will also help your gas mileage, and are much cheaper.
johnallen_king
Nov 1, 2024 06:32 PM
supersafety34
Mar 14, 2011 07:21 PM
Sooner0233
Apr 2, 2008 10:38 PM
tomgold
Feb 17, 2008 05:20 AM
broncoabe33
Jul 26, 2007 12:11 PM
