2003 6.0 AC Issues
Old Jul 16, 2018 | 03:54 PM
Kyle Rooker's Avatar
Default 2003 6.0 AC Issues
My AC when i start my truck will blow through my defrost vents and then after the truck "warms up" or has been running for a little bit it kicks back to my regular vents or whatever I have it on . I understand this to be a vacuum problem maybe? but what could the issue be ?
Old Jul 16, 2018 | 04:50 PM
There is an electric vacuum pump mounted under the hood on the passenger side inner fender well. With the key on the pump runs until it reaches a set vacuum in the system then shuts off.
If the vacuum reservoir is empty or low it takes a while to reach the shut off point.
I would suspect there is a vacuum hose either off or broken and the pump has to run longer to reach the shut off point or develops a high enough level for vacuum operated controls to work . A thorough check for any leaks should be made and repaired and the system should work as designed.
Old Jul 16, 2018 | 09:01 PM
Could be the pump itself, supply lines, ESOF if equipped can be another leak point..
941ton
Sep 15, 2010 10:30 AM
blitzn
Jul 4, 2010 08:19 AM
dgoodall
Jun 3, 2010 09:58 AM
jacobudo
Dec 22, 2009 11:03 AM
BHicks86
Jun 26, 2008 10:03 AM
