2003 6.0 PSD Gauge cluster dead...
Old Jun 11, 2007 | 10:57 PM
MightyYT's Avatar
Default 2003 6.0 PSD Gauge cluster dead...
It all quit short of the turn signals and high beam, Fuses good, gauge is plugged in, Help I dont want to go to the dealer
Old Jun 11, 2007 | 11:32 PM
Default RE: 2003 6.0 PSD Gauge cluster dead...
Key Off... Push and 'hold' the trip meter button in,, then cycle the key to the ON position (not start) and hold the button in until 'test' reads on the display.. Release... The gauge cluster should go into self test mode.. Once int test mode, 'each' push of the trip button will cycle to the next test step/function and DTC's for the cluster..Does it go into test?
Old Jun 11, 2007 | 11:39 PM
MightyYT's Avatar
It was fuse 45....run start feed, nothing even remotely related to what you would think it would be from looking at the fuse listing
Old Jun 11, 2007 | 11:40 PM
MightyYT's Avatar
Thanks HAYA!
Old Jun 11, 2007 | 11:50 PM
#35/10amp, #33/15amp, #45/10amp..
You can run the truck in test mode if you start it after it enters test.. You can bring up digital tach, digital speed/mph, temps ect... Glad it was a simple fix...
Old Jun 12, 2007 | 07:18 PM
MightyYT's Avatar
HAYA! Help....ran fine all day several hundred miles. When I went out a little bit ago it was hard to start, took three tries the I noticed no gauges again....same fuse blown # 45
Old Jun 12, 2007 | 10:51 PM
Did it smokeboth onstart up? or did the other pop on the road ect...
Old Jun 15, 2007 | 04:44 AM
Beater's Avatar
They have a recall or TSB on the cluster. Had one put in mine already. Same year truck.
sectlandscaping
Dec 6, 2013 10:27 AM
fireeater293
Nov 4, 2013 10:44 AM
blondiez24
Feb 11, 2008 12:01 PM
boaterhead
Jun 4, 2007 07:31 AM
jtt3769
Jun 4, 2005 12:12 AM
