2006 f350 6.0 overheating
Old Oct 8, 2021 | 12:01 PM
  #11
TFORCE's Avatar
thx everyone going to try all this out.
Old Oct 9, 2021 | 02:58 PM
  #12
TFORCE's Avatar
ok i found my leak without pressure tester, it was running as i was checking things out, and under the return bottle the big hose underneath it was leaking thru the clamp because of the pressure and all my water was evaporating under it, can any one tell me what that part is called it seems it is a plastic Y piece with the rubber hose factory attached. as i was adding coolant it was leaking soon as it cooled down it stopped so it was doing it only under pressure, so im not sure that is my whole problem but once its fixed ill recheck and recheck everything again for leaks, and im going to change the cap to i thought i could see some steam from around it.
Old Oct 9, 2021 | 03:04 PM
  #13
bismic's Avatar
Most people replace that plastic "Y" with a stainless "Y" from Leader evaporator: 1"x1"x3/4" SS Y SKU 3428
https://leaderevaporator.com/stainle...ing-y-fitting/
Wow - the filter isn't allowing the word "b a r b e d". This censorship is utterly ridiculous. This is the second site that wouldn't allow that word.
Copy the link above and put in that word where the asterisks are. Purchase the size tee mentioned above. You will have to crush the original plastic to remove the pieces and get 3 constant tension clamps, but it will then last forever.
Old Oct 9, 2021 | 03:13 PM
  #14
TFORCE's Avatar
Thanks bismic, ill order one now.
aprilhenry
Jul 25, 2020 06:21 PM
Hawk
Nov 15, 2013 08:05 PM
norby366
Aug 4, 2011 08:23 PM
randall russell
Jan 12, 2009 10:55 PM
Road_Rage_
Jun 27, 2006 01:53 AM
