2008 f250 starter issue
Old Jun 26, 2020 | 04:13 PM
Jnaas2's Avatar
Default 2008 f250 starter issue
Had a fail to start after 5 seconds time so released the key it returned to run position but the starter kept turning engine over until I turned it to off. Tried it again and it started Thing everything was good but something wasn’t right cause it did it again later so I ran a wire to the starter to check when it drops voltage to the starter and it does as soon as engine starts but if you just hit start it stays on until you turn it off
Old Jun 26, 2020 | 04:16 PM
bismic's Avatar
First thing I would look at is the starter relay.
Old Jun 26, 2020 | 04:33 PM
Jnaas2's Avatar
Switched out relay to rule it out that wasn’t it. I ran the wire to the starter solenoid to check when the power dropped off it. It stayed on after attempt to start the truck but as soon as the truck starts the power drops off. I’m wondering if the pcm is malfunctioning
Old Jun 27, 2020 | 09:42 AM
What engine, build date?
Old Jun 27, 2020 | 11:07 AM
Jnaas2's Avatar
Don't know the build date but its got the updated heads that don't blow the plugs out
HULLTECH
Mar 17, 2013 09:41 AM
romeodz
Jan 29, 2011 07:16 PM
okie
Mar 19, 2010 02:39 AM
87ford150longbed
Feb 5, 2008 02:42 PM
purefury
Nov 26, 2007 06:07 PM
