302 Intake on a 351
Old Jul 1, 2010 | 06:47 PM
Temptech's Avatar
Default 302 Intake on a 351
This is interesting! All I hear is the 302 intakes will not fit a 351, but alas I have just that in my old truck. The intake is marked with the 302 firing order but the truck runs nearly perfect using the 351 firing order. I am missing something here?
Old Jul 1, 2010 | 07:56 PM
Use Common Sense's Avatar
If your 351 Windsor motor was a 1976 or ealier build, then the 302 intake would not fit. From 1977 onward, the 351W shared the same head casting as the 302, differing only in bolt hole diameters (7/16 inch for 302, 1/2 inch for 351W).
Old Jul 2, 2010 | 07:11 AM
Temptech's Avatar
Default To common Sense
Thanks for the clarification, correctness is in the details. Now the question becomes;assuming the 351 is taller, will a 351 intake significantly improve engine performance?
Old Jul 3, 2010 | 01:49 PM
Temptech's Avatar
Default 302 or 351
Since the firing order is for a 351 I assumed the engine is a 351. However the oil pan gaskets from the auto parts store for a 351 did not fit but those for a 302 did.
Old Jul 3, 2010 | 08:16 PM
hotrodstude's Avatar
in the late 70's/80's ford was screwing around with the firing order on the 302.find out what year you have then go from there
Old Jul 4, 2010 | 01:39 PM
Temptech's Avatar
Default 302 vs 351
Thanks for the suggestion, I will look Tuesday. But I may have stumbled upon what is going on. I think the block and intake are 302 but the cam is for a 351. I found the explanation on an old Ford Mustang thread. The question now becomes; would I be better off using a 351C I have that has already be bored out. It will need a good machine shop re-freshening but it also has an Edlbrock manifold and a 2 bbl carb. Would a 4 bbl help with power in an F350 Bucket truck?
bwbogott
Jan 23, 2011 03:17 PM
stutzman
Jan 13, 2008 07:11 AM
Hbombmike
Sep 16, 2007 11:04 PM
catfish3266
May 22, 2006 12:52 PM
gt_ute_351
May 1, 2004 11:48 PM
