6.9 diesel brake woes
Old Oct 21, 2005 | 07:07 PM
KSA's Avatar
KSA
Default 6.9 diesel brake woes
Hey guys, a I am having some problems and want to try and fix it them myself. I have a 1983 f-250, w/the 6.9 The truck was parked from july to sept so I could replace the steering gear seals and the fuel pump. When I started driving it again a few things happened. When I press on the brakes they don't respond well, I have to press real hard to stop the rig. At highway speeds and high idling the brakes work fine. The dash brake light is on all the time except at high speeds. The vacuum pump hoses appear fine, the belt is on the pump and the pump is turning, it is not using fluid, so wheel cylinders are not the culprit. I am thinking vacuum pump or brake master cyl, I don't want to buy parts and started hanging them until I fix it, any ideas out there? Thanks
Old Oct 22, 2005 | 12:28 AM
rusty ol ranger's Avatar
Default RE: 6.9 diesel brake woes
Im beting on your Power Brake Booster.
Your diapram (sp?) is probely getting ready to go out and only provids assist when there is high vaccum on the engine (little load or high idle).
later,
Dustin
Old Nov 11, 2005 | 12:52 AM
mpadly's Avatar
put a new vac pump on and you will be fixed.............
Old Nov 11, 2005 | 01:00 AM
hockeyhitman69's Avatar
SOUNDS LIKE VACUUM PUMp
Old Nov 11, 2005 | 02:08 AM
mpadly's Avatar
I'm a shop foreman for a ford dealer ship I see these all the time i can almost garuntee that is the problem... hope it works for you
sannis
Dec 22, 2007 11:25 AM
skoda
Nov 26, 2007 02:31 AM
raggy742000
Oct 23, 2007 08:59 AM
mattymax
Mar 2, 2006 12:46 AM
savvy5473
Sep 7, 2005 02:31 AM
