7.3 air in fuel problem need help
Air is getting in through the suction side of the fuel pump. It could be a poor seal at the tank where the lines connect to the tank or possibly a hole in the pick-up tube inside the tank. If you can insert a piece of clear tubing into the suction side line , which won't be easy with the locking connectors at the connections, you would be able to confirm/isolate the source of air entering the system.
Rooster89
Apr 22, 2008 05:22 PM
