'75 F-350 won't start
Old Apr 20, 2011 | 08:49 PM
gcarrboy's Avatar
Default '75 F-350 won't start
Need some help. I have a 1975 F-350 dump with a 390 ci engine. I've changed the solenoid and the starter and have charged the battery but when I turn the key, the solenoid just clicks. I've cleaned all the electrical connection from the battery to the starter. Never had this much trouble getting a Ford to crank.
Old Apr 21, 2011 | 04:03 AM
Do you have any provision to hook up a jumper battery? If you do try and see if it makes any difference when trying to start. Not knowing what equipment you have available to test with, I have to be certain the battery is good and the charger is working .
After that are you able to at least move the belts and see if the engine is free to turn.
I don't remember if they used two solenoids in the starter system on those older bigger engines. Sometimes the solenoid will pull in when energized , but not well enough to send enough current to the starter for it to operate. With a test lite confirm that you are getting voltage down at the starter itself.
Old Apr 21, 2011 | 07:33 PM
gcarrboy's Avatar
Thanks Hanky. I took the battery and had it tested today and sure enough, it was bad. This truck has an electric dump on it and it worked fine, so I thought the battery was good. I had tried jumping it as well, but it wouldn't start that way either.
Old Apr 22, 2011 | 02:20 AM
If you still have the no start condition, do you know if you are getting spark to the spark plugs?
Old Apr 24, 2011 | 08:25 PM
gcarrboy's Avatar
Thanks hanky, but the new battery did the trick.
frankjr
Feb 26, 2014 11:02 AM
fordosaurs
Dec 8, 2011 12:11 PM
letsfixaford
Apr 14, 2008 07:52 AM
fordmann67
Nov 11, 2005 12:42 AM
hseabert
Jun 30, 2005 10:32 AM
