87 F250 7.5l power loss
Old Mar 26, 2020 | 11:13 PM
led3roy's Avatar
Default 87 F250 7.5l power loss
I am not a mechanic to start with but do a lot of my own work on my vehicles.
Starts and Idles fine, but loss of power once in gear/load (even second gear). newer 1406 Edelbroch 600cfm carb. new wires, spark plugs, coil, distributor cap. New see thru fuel filter just before carb and showing plenty of gas. I did not replace the Ford fuel shut off valve that sends fuel back thru a return line and I do not see a color dot to know the right size.
This has been my workhorse for many years then the old holly started leaking fuel out all over it. I had a mobile mechanic look at it and he suggested removal and replacement of carb to the edelbroch and removal of all emission equipment. Truck ran fine for a year after then the trouble started. Has set for several months. Once I found out that the Fuel Shut Off Valve was not a fuel filter, I realised the mechanic never put on a fuel filter. Today I disassembled the carb and cleaned out the carb thoroughly and put it back together. She started right up and idles great, but same power loss issue once in gear.
Any help out there? or should I break down and get her to a good garage?
led3roy
Mar 28, 2020 04:41 AM
Schmankew
Aug 28, 2018 01:36 PM
tme
Dec 22, 2015 03:32 PM
BitterBluePoison
Jun 27, 2011 02:16 PM
nduetime
Apr 13, 2008 12:21 AM
