90 f250 brake pedal goes to floor
Old Aug 31, 2011 | 05:02 PM
welderbill's Avatar
Default 90 f250 brake pedal goes to floor
f250 4x4 460 e4od trans.. installed new master cylinder,bled out fine,brake pedal goes to floor..brakes adjusted fine..why does pedal still go to floor? please help thank you
Old Aug 31, 2011 | 06:39 PM
It's always the question of why did you need to replace the master cyl.
If,,, there were no other problems that we don't know about,
If you bench bleeded the master cyl before installation and there were no other leaks in the system usually you could rebleed the lines at the MC and you should get some kind of decent pedal. If you did everything correctly then it is possible the replacement MC is defective on the other hand if there was another reason such as a leak somewhere that you repaired then you would need to bleed the entire system.
Old Sep 6, 2011 | 09:35 AM
welderbill's Avatar
Master cylinder 21yrs old...just crapped out no leaks everything good pedal still goes damn near to floor...btw new master cylinder IS BRAND NEW what else should i be looking at? entire system bled twice NO AIR
Old Sep 6, 2011 | 10:46 AM
Gary2Wheels's Avatar
Thumbs up
it's always best to bleed the longest lines first..betcha it's still 'air logged'
Old Sep 6, 2011 | 08:02 PM
Don't know what sequence you used to bleed the lines, but it usually is RR,LR,RF then LF.
Ya gotta make sure you keep the MC full all the time. It does require a lot of fluid to do the entire system correctly.
bigdaddy1
May 2, 2013 07:17 PM
petec
Jul 26, 2012 09:57 AM
petec
May 21, 2011 11:55 AM
hicksw00
May 14, 2010 06:14 AM
cope607
Mar 13, 2006 03:56 PM
