94 F250 volt meter reading high/high idle
My 94 5.8l F250 4x4 the volt meter is reading high and occasionally the check engine light comes on and the idle speed jumps up I checked the codes koeo and got 122,654,522 I'm not sure the issue the code 122 referred to the tps but I'm wondering if my problems are stemming from the volt meter reading high I would appreciate any advice or a point into the right direction
12.73 engine off 14.23 engine on
and now the volt meter in the dash has quit working or at least is bottomed out below 8 and the fuel gauge has stopped above qtr there not that much gas in it also when driving it the throttle has quit responding after a qtr pedal and it shifts into high gear then drops back into low gear and throttles up over and over until it reaches a speed fast enough for high gear
Bruce Landow
Apr 9, 2018 09:38 AM
surferjoegomango57
Dec 11, 2013 02:32 PM
